RYZEN CPU %100 and FPS DROP
kiracata
6
Hi. İ have problem with my new system.
. During the whole game my cpu is between %90 and %104. And it has low performance and fps..Sometimes fps suddenly drops to 1-2 and freeze image. İ playing lol on 70-90 fps and sudden fps drop 20-15.
İ tested system cpu z and gpu z
Statistic:
Temp: cpu 57 degree 47 degree 73 degree 67 degree max
CPU use min :%90 max %104
Gpu use min %0 max %87
Scan hdd: clear
Scan eset nod 32: clear
My system
Ryzen 3 1300x
Msi a320m motherboard.”
Asus rog strix 1050ti
Team 8gb ddr4 2133 ram
Aerocool kcas 600w 80+ psu
Kingston 120gb ssd
Seagete 1 tb hdd
Wiewsonic 24’ 75 hz full hd
İ have Windows 10 pro
Eset nod 32
İ Need help and sorry ı have bad english
Depending on your settings, 100% CPU and GPU may be normal. If your CPU doesn't throttle and setting Windows to high performance mode doesn't help, then you still need to figure out what causes the FPS drops to 1-2. Most people who buy that CPU overclock it to get better performance.
Owwww. My problem is this. Same fps and usege CPU and GPU On LOL And other games are bad. Black OPS 3 CPU use 98-104 and Gpu use 0-57. This İs real ‘0’ and freeze windows.
Yes this is correct. Gpu and cpu use same this video. I have 3 games. Most FPS drop in black OPS 3. Dropped 1 fps and freeze. CPU use 98-104. Gpu use 0-57
What do you have to do when it freezes? Reset the PC? I read several Ryzen and Black OPS 3 threads and FPS drops often seems to be an issue, but none has as many issues as you do (they drop below 60, but not to 1). You confirmed the CPU doesn't overheat and the frequency doesn't drop while gaming, but huge FPS drops usually often are caused by a CPU that overheats. If the CPU frequency never drops and it's that busy, then something is wrong with your settings or you run something else in the background. Are you overclocking the CPU?
Not supported oc in my motherboard. %100cpu and %0GPU is normal? CPU is bussy %20 Windows services. On game and close game. And sudden %50 60 if i open something window 1-2 second. (Picture, task manager, folder)
