Ryzen high temps??
twantenho
16
Hello,
I am just done building my pc and decided to take a look at the bios (haven’t installed windows yet) and noticed that the temps of my 7 1700x are around 50 degrees, what I find quit hot when the cpu is just on the bois. So I decided to do some research and found out that ryzen has a +20 degrees in the bios, because of the cooling of the cpu fan. Will that mean that my cpu temp. is around 30 degrees? Idk, probably I guess. Do you people know something about this??I think I will just install windows and download some software that will show the real temperature, if it is true what I say 😛
Already thanks for reading
First off if you haven't already install the latest BIOS for your motherboard, Ryzen has had a lot of changes since release. Secondly yes that was an issue with Ryzen but has been corrected with BIOS updates on many boards. Go ahead and install Windows and then you can monitor the system while Windows is running that will give you a more accurate idea.
