ryzen idle temps
normiecs23
52
Hello guys, I have a Ryzen 3 2200g running on the given iGPU. 2 Months ago, it would be running 24 degrees celsius on idle, but now is around 30-33 degrees celsius on idle now that I benchmark it. Is there any issue to worry about? and what would a ryzen cpu with 65w tdp temp be for idle?
Those temps are fine, what are your temps in load? You can always buy 3rd party thermal paste for example Mx-4 or Kryonaut and replace the stock one which is not the best performing. Or get better CPU cooler if you are that worried about temps. If you're not getting 80°C in load you should be fine. Do you have any exhaust fans in your case? If not you should add one because it can help a lot with temps.
Nothing to worry about. That is totally normal. Depending on some variables, idle temps can be pretty low about the 28c mark. For most systems idle will be 30-35, or at least that's where it should be.
Temps should roughly be in these ranges.
IDle 30-35, gaming 45-65, stress testing 65-80c. Of course these temps will differ slightly for every system. This is mostly attributed to what cooler is being used, and how complex the CPU might be (more cores will have higher TDP and can generate much more heat than the 2200g).
You're good to go.
