Ryzen overclocking help needed
Jariuiuiuiuiuiiu
So i'm trying to OC my ryzen chip (r5 2600) , using an ML240L by cooler master. In a program called ryzen master i can keep a steady 4.1ghz at 1.425v however, when i want to apply it in BIOS it doesnt let me put a higher voltage offset than +204v.
Can anyone explain this/Help me?
Thanks upfront
My other specs:
CPU: Ryzen 5 2600
Motherboard:Gigabyte B450 Aorus Elite
Ram: 2x8gb LPX Vengeance @3000
SSD/HDD: 128gb kingston ssd, HDD 1tb 7.2k
GPU: RX580
PSU: Techsolo STP-650 PSU
Chassis: Phanteks Eclipse P400
OS: Win 10
If 4.1 @ 1.425 is stable in Ryzen , just move those to Bios settings,
default 2600 is 3400mhz, just look in Ryzen Master and see what the voltage is at,
1.425 - v Ryzen Master = your offset
make sure you have CPU...
make sure you have CPU Vcore to Normal
add your offset under Dynamic Vcore(DVID)
under advance frequency settings put Clock Ratio to 41
save & restart
* I don't have that board, I just looked at the bios screens 🙂
https://www.kitguru.net/components/motherboard/ryan-martin/gigabyte-b450-aorus-pro-motherboard-review/all/1/
*also your max XFR on this CPU is 3.9 single core, I don't think 4.1 all core will be stable under stress !!!
well i have 1600x which clock a little bit worse than 2nd gen, tdp is similar for same clocks
mine 1600x when oced to 4.1ghz on all cores with 1.375v vCore and +75mV offset (1.450v) will go during stress testing to a nice 180w power draw (55-60C temperature with 240mm radiator with 4 fans at low speed)
