Ryzen power plan
sneeken
15
Hey. I "accidentally" deleted my ryzen power plan, as it was in another language i did not understand. Ive now tried to reinstall the chipset driver from AMD, but it doesn't come back. Any thoughts on how i can get it back?
If you go into the AMD folder where the chipset files are residing (c:\AMD\amd-chipset-driver etc navigate to \packages\apps\RyzenPPM and there will be an installer also called RyzenPPM.
As i said, iv'e already done that. Doesn't come back.
Correct. Only Balanced (the default microsoft one), and performance
AYY! Thank you! I dont relly know why it's still in Polish though. I'm norwegian and have no other Language packages installed. Do you have any clue about this? :) Thank you in advance!
It's a well known localization issue within the chipset package itself. I have not set out to diagnose it because it doesn't occur with English, but it does occur in MANY non English languages. For example Korean locals get a Russian install.
So this is normal? There's currently no fix? Maybe it'll change in the next update then?
Anyways, thank you so much for the help :)
