I have a Ryzen 7 1700 and the power plan is not showing up in power plan options? Does the Ryzen power plan replace the normal windows one or should there be a renamed "Amd Ryzen Balanced".
Ive tried that already I downloaded it and restarted it twice and the power plan still doesn't show up 🙁
I understand and many others have had this issue. Make sure your W10 is up to date.
Try this:
Open your Windows files directory to where the AMD directory is installed.
AMD>Packages>Apps>RyzenPPM There should be an MSI file named RyzenPPM.MSI. Run this file with admin privilege and see how you go.
