Ryzen RGB cooler cable?
There's no RGB header on that motherboard, so nowhere to attach it, unfortunately.
No, it will not work on a 4pin fan header..... and may potentially cause damage.
Barty1884
Retired Moderator
The header does more than just provide "power", there's software control to actually run the RGB etc; so something like molex to RGB doesn't (or shouldn't) exist.
The only route to go, if you have no RGB headers on the board would be to add something like a Hue+, which I believe you should be able to connect to the Spire to.
