Ryzen temps 85 idle help!
May 19, 2018
Hello I've just built a pc with a Ryzen 5 2600x and a msi b350 tomahawk I booted up installed drivers and I used speccy piriform and it read 80 idle!! I am using cooler master masterliquid ml240l and artic Mx-4 someone plz help!!
Sounds like either your cooler isn't mounted securly, your fans or pump aren't running properly. Shut it down go back over everything and make sure that things are where they're supposed to be. Usually it's something small that was overlooked while the excitement of building your Pc has you somewhat distracted. If that doesn't work report back
