Archived from groups: alt.comp.hardware.pc-homebuilt,uk.comp.homebuilt (More info?)
At the moment I have my 200GB SATA drive on SATA-1(IDE CHANNEL 3 master).
This drive has windows installed on it, and is the only Hard drive in my PC.
On IDE channel 1 master I have my DVD Drive.
I need to install a 250GB IDE Hard Drive, for storage. I'm not too sure on
which channel it should go? IDE Channel 1 Master and then move the DVD to
slave?
On another note, the is the first time I've used a SATA drive in any system.
There's always a little icon in the system tray "safely remove hard drive",
this seems a little scarey to be constantly there? is it normal?
slave?
