[s] Tile problem
G
Guest
Guest
Archived from groups: rec.games.roguelike.nethack (More info?)
Hi,
Just downloaded Slash'em, but when I run it, the
tiles are so dark I cannot really see anthing. I
had the same problem with NH, but since the tileset
is in bmp, I just edited it to lighten it. How can I do this with Slash'em
? The tileset is a file...
On Sun, 13 Mar 2005 15:52:41 GMT, also sprach "K.V.C"
<kvc627@earthlink.net>:
>Hi,
In your defaults.nh there should be a section for selecting tilesets,
thus-ish:
TILESET=name:Big tiles,file:gltile32.png,transparent
OPTIONS=tiles:Big tiles
There are plenty of tilesets you can find and download. Just gamma
correct those files as needed.
Keiran
My question is how do I edit the tile set. It isn't in any
format that I know. Acdsee, Photoshop, Paintdotnet
do not recognize it. If I convert it into a recognizable
format, I cannot then revert it back to a file.
My default file looks like this:
TILESET=name:Big tiles,file:x11bigtiles,transparent
x11bigtiles is just a file...I'm stumped. If I change
it to TILESET=name:Big tiles,file:x11bigtiles.bmp,or jpg or png or any of
the other 10 or so
picture files the program will not recognize it.,transparent
<BTW where can I find other tile sets ? I keep finding NH not slash'em
tilesets.>
"Keiran" <furyqba_spamtag@yahoo.com> wrote in message
news:l6aj319115fhm49sfhcqpt7o9687trg2sq@4ax.com...
>>Hi,
>>Slash'em
> thus-ish:
> Keiran
