[SOLVED] S36 Fitting Problems
Jun 24, 2020
Is there any way you can fit a S36 into a Meshify C? It seems like you have to take some of the base off, but I am not sure how this will work.
If the S36 is the Fractal S36 360mm rad AIO then according to fractal, it might. It's dependent on if the tubes will reach from front of the case to the CPU socket. I think they will.
At the very least there is enough space in the front of the case to hold the 360 rad, but not sure if the tubes will reach. Yes you will have to remove some of the PSU shroud in the bottom.
