Hi all,
I have decided to try and build a workstation using a S5500BC server board.
I have 2x Intel Xeon E5540 CPU's with 2x Corair H45 AIO water coolers installed, along with a Cooler Master RS-600-ASAA power supply.
When I attempt to power up the machine all the fans spin up for a few seconds and the 1-5-4-4 beep code sounds.
(1-5-4-4 /Power control failure (for example, power good from the power supply did not respond to power request))
Official documentation states:
"A minimum of 400 W is required. Your supply must provide a minimum of 3.5 A of 5 V
standby current or the board will not boot."
-https://www-ssl.intel.com/content/dam/support/us/en/documents/motherboards/server/s5500bc/sb/e52448002_s5500bc_user_guide_rev_2_0.pdf
-page 32
I am hoping that this is a power supply issue and that I haven't bought a dead board (ebay). I can't find a value for a standby current on this power supply and it does not have the Intel Power Supply Auxiliary Connector, which I believe the use of is optional.
Can anyone advise on the next steps that I should take?
Thanks in advance,
Chris
Note: I have come accross this link which is a guy trying the same thing with a little more success.
https://communities.intel.com/message/412418#412418
-page 32
Thanks in advance,
Chris
