Hi guys, newbie here hitting a wall with this new system I built.
ASUS Sabertooth 990FX AM3+ http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736&cm_re=sabertooth_990fx-_-13-131-736-_-Product
Phenom II 955 black
Corsair Vengeance 2x4GB
Crucial M4 64GB SSD (Boot Drive running Windows 7 64 Bit)
WD Caviar black 1T 7200 SATA 6GB/S
After installation, I did a few service / OS changes to optimize my SSD based on web reviews / guides and then tried to install drivers. It looked like all the drivers were installed, the JMicron and RealTek Audio/Lan. But my chipset drive seems to not work, when I tried to install it from the DVD, or a newer version downloaded from the Asus website (I ran it as admin). A command prompt opened, and 10 seconds later it disappeared and then nothing is happening, I'm assuming that this means there is something wrong, because aside from nothing popping up, there was no confirmation or prompt to restarted my computer. I called Asus but 2 of the tech I got were either too dumb to realize what I'm even asking, or just repeatedly told me to update my bios to the SAME VERSION I already had on the MoBo.
Long story short, any expert or owner of this particular board can shed some light as to what is happening when I tried to install the chipset drivers? Did it work in the background? How do I verify in windows that the chipset drivers have indeed been installed, or not.
Phenom II 955 black
It ran, in Vista, for about... 7-8 hours, @4.0GHz, 2000MHz ram, before crashing, but i just couldn't quite stabilize it at that speed, so i had to back it off a bit. It's been solid ever since.
