Sabertooth 990FX R2.0 with AMD FX 8350 Processor problem
Sven Skretting
14
I built my friend a computer this weekend and put everything together and checked, double checked and then triple checked everything was connected.
I then plug it all in and start it up, The PSU powers on and the motherboard starts up, but we get no signal for the monitor and keyboard/mouse.
I've gone through the step by step guide here to check if everything is correct and it is, and i've searched the web a little bit to see what the problem could be and the only logical answer i could find was that the AMD FX8350 processor did not work with that Sabertooth 990FX motherboard because you needed a updated bios or something?
Can this be the problem why i'm not getting a signal to the monitor, mouse etc ?
The set up is as following
ASUS Sabertooth 990FX R2.0, Socket-AM3+
AMD FX-8350 8-Core Processor
Corsair DDR3 16GB 1600MHz Low Profile
XFX ProSeries XXX Edition 750W PSU
Nvidia Geforce 580 GTX Graphics card.
Seagate Barracuda® 1TB
I should mention i tried with both his monitor and mine which i'm using now.
Thank you in advance
You need an updated bios for that setup, at least ver. 1006
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=24&m=SABERTOOTH%20990FX%20R2.0&os=&hashedid=Yk1gGoRISkgLawoj
Luckily that mobo's BIOS can be flashed without a working CPU.
(assuming you are running win7 64, just select different from drop down if not)
http://support.asus.com/download.aspx?SLanguage=en&p=1&m=SABERTOOTH+990FX+R2.0&hashedid=Yk1gGoRISkgLawoj
Stick the BIOS in the top level of a USB stick, plug into your machine and press the BIOS Flashback button for 3 seconds with the power supply connected.
And with this solution i will get signal to the monitor ?
It is a problem ASUS has with AMD boards - I have this board and use the AMD 3.4gig FX965 processor - I get the CPU LED light red and am awaiting my 3rd board from ASUS - 5 weeks and counting of dealing with them. My next board will not be with them or ASROCK (ASUS owned)
