I just built a new 1155 rig
2600k i7
Radeon HD6950
12gb of dominator @ 1600
128gb SSD
Also running with a 1000 watt PSU
So the issue is I can't seem to get the board to boot any of my drives. I get 1 beep on post which seems to mean normal operation in the manual. But then I get the boot device light error. Which makes sense, because If I try and boot a HD from my old setup I get the XP logo screen and then it hangs and blue screens every time. Error says to check drives for instability. However I get the same error if I try to fresh install XP on the new SSD. XP loads from the disc fine, but as soon as the installation process starts it blue screens.
I've tried using different sata ports and nothing works.
Not sure if this is related or not but the bios sata function show only 6 of the 8 ports. 2 of the 6 gb ports aren't even showing up if I have something plugged into them. I can seem them in the boot device menu though so I'm not sure it matters.
I'm not sure if flashing the bios will help or not.
Any help would be great.
2600k i7
Radeon HD6950
128gb SSD
