Safe load for EVGA G2 750 80+ Gold PSU
BishBashBoris
Hi All,
Long time listener, first time caller. Quick thanks for all of the excellent advice I've seen on here previously.
My question relates to my EVGA G2 750W 80+ Gold PSU. My system is MSI R9 390 + i5 6600K. I'm thinking of adding a second GPU exactly the same, now that they're going a bit cheaper, and am wondering if it will be safe to run with my PSU. I also have 4x DDR4 2666 RAM, 2x SSD, and 4 120mm system fans (three plugged into mobo, and 1 direct to PSU).
The MSI 390's push the clocks up to 1060mhz core, and 1525mhz memory. I'll run the CPU at stock 3.5ghz @ 1.2v if necessary.
The online calculators are telling me a total load of around 650w, and are recommending an 850w supply.
So my question is really how bad would it be for my 750w to run the 2 x 390's in CF? Potentially running at 90% load.
Edit: PSU is less than 1 year old.
Full specs:
Gigabyte Z170XP-SLI
i5 6600K
MSI R9 390
Kingston Hyper X 4gb 2666 x4
Samsung 850 pro 250gb SSD
Samsung 850 pro 1tb SSD
EVGA G2 750w 80+ Gold
