On forums nearly everbody talk about 1.400 ~ 1.520 and upper values for Vcore of i7 2600k for 24/7 daily usage will degrade the lifespan of cpu.(assume that temps are good).
I talked with Intel's Technical Support Engineer on the live chat support about this topic and he said that below the 1.520 Vcore is absolutely safe and will not degrade the lifespan of i7 -2600k.
I want to use mine with ~1.450 - ~1.480 Vcore for 24/7. If i degrade my cpu's lifespan or even if i damage it (assume temps are all fine), it should be in terms of warrent and i can rma it.
After these chat wit Intel's Technical support would you suggest using this cpu with ~1.480 Vcore ?
