Hi,
Going to try to build my first computer soon. I read that a wooden table is a safe place to build it on but I have a big carpet under it, will that be a problem? I'm building it at my mom's and she has carpets everywhere...
Is there anything else that I should take into consideration? What are the main ways new builders destroy their parts? Also, do you suggest putting the motherboard, cpu, video card together before it is in the case and plugging it into the psu to check if everything is working?
Thanks
Thanks
