Avac :
I am using Prime 95 v.28.7. The temperatures according to Chattahoochee were from using 26.6. 26.6 temps can be much lower than 28.7. I will download 26.6 and see what temps I get.
Again, I don't see the purpose of doing so. If your goal is to go on forums and tell peeps that your system does this w/ P95, then I guess it serves a purpose. But if your goal is to determine stability of an OC with a modern CPU .....
1. What is the purpose of using an old P95 which does not utilize modern instruction sets ? You have proved that your CPU is stable under P95 as long as you don't use all of the added modern instruction sets which are designed to aid CPU intensive programs in modern CPUs. Kinda like testing the off road capability of your new jeep by going off road in 2WD mode.
2. What is the purpose of testing with a "1 type of load at a time" synthetic test like p95 if that same OC can fail under CPU intensive applications especially in a multi tasking environment which P95 does not test..... not the old versions, not the new versions.
3. What is the purpose of testing a synthetic load which no modern application or combination thereof can apply ? If you intend to search for the next mersenne prime, the sure.... but if your intent is to run applications and games, since P95 will make your CPU 5C or more hotter the any application based stress test will result in, why unnecessarily limit your OC because of temp concerns when nothing you will ever run on your computer will approach these temps.
P95 make s sense for testing CPU coolers for example where it applies a consistent non varying heavy load. This is useful for eliminating variables which may occur under testing and is useful for determining cooler performance with reference to other coolers. But using P95 for determining the highest safe and stable overclock just doesn't satisfy the goals for this task. As indicated before, I have had stable P95 OCs fail when using a multi tasking benchmark like Real Bench so stable under P95 does not equal stable under actual applications in a multitasking environment
http://rog.asus.com/forum/showthread.php?43233-Realbench-v2-Discussion-Thread-Download-Links
http://www.hwinfo.com/download.php
