http://www.amazon.com/Unitek-Extension-Adapter-Compatible-Smartphone/dp/B00KMKKJWW/ref=sr_1_5?ie=UTF8&qid=1448742767&sr=8-5&keywords=unitek+4+port+usb+hub
Heres the usb hub that I just bought.
I have 5 portable 2.5 inch hard drives i want to connect to my laptop, and there are only 2 ports available. So I got this hub. How many hard drives can I safely plug into the hub? My initial test with 4 hard drives plugged in seemed ok, but then I had some trouble with one hard drive being read, and it kept disconecting and reconnecting and making clicking noises(I plugged it back directly to my laptop and it works fine, so its not broken or anything). But so you know, I do not know if this is the issue with my hard drive or the usb port, because even without the usb hub, my hard drives have occasional difficulty being read and making clicking noises because my usb 3.0 ports are very unstable. Most of the time they work just fine, no noises. Its very inconsistent.
