safe to convert SATA power cables for second PCIe power cable, using adapter ? [with specifics]
delicious-unix
Commendable
Aug 6, 2016
so here is my power supply:
serveimage
and a little more info: http://www.bequiet.com/en/powersupply/326
i am looking to connect a HD 6850/6870 to this computer, which requires two PCIe power cables.
according to this, the maximum power draw of the 6870 is 150W
http://www.bit-tech.net/hardware/graphics/2010/10/22/ati-radeon-hd-6870-review/2
however, the power supply has only one PCIe connector. but i do have tonnes of spare SATA power cables. can i buy an adapter that will connect the SATA cables to the power supply, safely ?
the computer uses an i5 2400S and the bare minimal of other components. i have read that a two way splitter on a PCIe power cable is a bad idea
i have also contacted the manufacturer of the power supply with the same question
i thought 'be quiet' was good quality 😱 they had the best component wattage calculator, a solid website, the brand name that is germany (although VW dented that). i don't know how to choose a power supply brand based on actual electronics, but it wasn't cheap compared to other brands
anyway i have discovered the 6850 actually only needs one PCIe power supply ! so i will probably buy that, or a 6790, or 7770, both are a bit less powerful, but just below the threshold of needing two PCIe power cables
i was, much earlier, also looking at the 5850 and 5870, but they are less power efficient, and both need two PCIe cables.
