Got a Cooler Master Elite 110, a Gigabyte 1070 Mini GPU, and a 6700k cooled by H80i V2. Will the GPU be damaged if two 80 mm Noctua NF-A8 exhaust fans are placed absolutely right in front of the GPU fan, with almost no room between them at all, perhaps only a mm, but airflow in the same direction?
Without the exhaust fans, will temps be low enough in the case for the 6700K? Got a small Corsair SF600 psu about 2 cm below the roof of the case, so guess its fan will blow some of the hot air near the roof outside the case, right?
If the two 80 mm fans are safe right next to the GPU, how does one use the rubber mounting screws to attach the NF-A8 when I can't see how there is room to use pliers down at the bottom rubber screws, since the two fans are at the floor of the case, right next to each other.
The rubber screws can't be drawn at both ends, one end has to go through the case wall first, and then one can pull the other end through the hole in the fan frame, but the screws are not that long, so can't see how this is possible in the small space of the CM 110. Any other screws I can use?
