[SOLVED] Safe voltage for 2700X with POB on?
robertdegges
20
So I enabled POB in BIOS and in ryzen master.
Voltages
Ryzen master: average 1.53
Hwininfo: average 1.425 with a max of 1.444
Getting a pretty much constant 4.275 ghz on all cores
Temps:
Tctl: max 72C, average 47C
Tdie: max 62C, average 37C
These temps are after running Heaven benchmark
Setup:
2700x
Taichi X470
H105 AIO
What do you guys think? All I did was enable POB, did not mess with anything else.
Sorry can you show me in a screenshot the exact settings?
Cause if it's a motherboard feature by Asrock, then it's bad.
But if it's a feature by AMD it is ok.
I think I’ll leave it as is and uninstall Parkcontrol.
With the cores parked, I don’t think it’ll effect gaming? I’m sure it’ll use them when it needs. Just had it for my 8350
Figured I would update:
I reset the bios to default, and reenabled XMP and the XFR(POB)
Uninstalled parkcontrol and set the windows power plan to balanced.
Ryzen master is now downclocking to 0.8V/2200mhz when idle and under load goes to 1.36-1.444V(4275-4300)
Temps don’t go above 60C.
So I’m happy with it now.
One weird thing is when I put it to sleep, it won’t wake up. After googling this issue for a while, I’ve decided to just not put it to sleep lol
