Hello
i am having an strange problem and that it i get a very set amount of fps in each game regardless of what resolution or graphics settings i use , if i can get 150fps on ultra and native res i can only get the same amount on very low on a very bad res
i used afterburner to check the temp and usage and cpu and gpu were on 40% most times except for a few spikes to 70-80%
i do have my gpu drivers installed with the game ready drivers also i know that the said game does not have an fps cap unless you set it which i did not
my pc is using i7-7700k with gtx1070oc and z270e mobo
if you can even think of anything that can help me it would be much appreciated
