same cooler like CM 212 evo?
aggelos123
254
5 days ago i built my first budget gaming pc.(budget) and i have noticed that my cpu temps while gaming arent good...(70C with the stock cooler of amd)..cooler master hyper 212 evo is 40 euros...i am in a strong budget right now...can you show me a cooler that is a little bit more chaep than this and to do better job than the stock one?
my cpu is AMD athlon x4 750k.well i consider buying cooler master hyper TX3..i read good reviews about it and it costs 20 euros here...half of the price of 212 evo...will that one do a good job dropping my temps while gaming?(right now with the stock cooler my temp while gaming is 70C!..this is what i dont want..i dont want 70C while i am gaming...what do you think?
i am thinking of buying this one cuz is half of the price of 212 evo...i will not be overclocking but i will be gaming..COOLER MASTER HYPER TX3
should i go with COOLER MASTER HYPER TX3?its half of the price of 212 evo...
what country etc
as for fan i would suggest spectre fan pro 120mm for rear it will pull more air out the case
as for cpu cooler
only one comes to mind that may be cheaper in your area like i said dont know were you are so search these few
CNPS10X-OPTIMA
Hyper T4 CPU Cooler
