Same hardware reserved problem...AGAIN!!
hillelslovak
147
Ok, I had this problem for a few months around the start of this year. My system is
Ok, I had this problem around the start of this year. For some reason, out of nowhere, I had around 5.9 of my 10gb of ram actually usable. I had not ever messed around inside the pc, and had never reset the ram sticks. After seeing this, I reseated all the sticks, the pc booted with a single stick on every slot, but I still could not utilize the entirety of my memory. So around March of this year I decided to buy an this ram stick: https://www.amazon.com/gp/product/B005T63BJM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
For some reason, after putting in the new stick, I had all 18 gb usable now. I have no idea, but after blowing the dust out of my pc yesterday, the system was stuck on the hp logo, and would not start. So I checked all the plugs in the computer, made sure the ram was all seated properly, etc. It had the full 18 gb then. This afternoon however, I load up, and see I only had 10 gb usable. Weird. So I left my 4x2 ram sticks, and the 8gb one out. Now I only had 7.8 usable. Crappy, so I put the 8gb one back in, took the 2gb one out, and resetted. Now it had like 5.8 usable. I then put the 8gb one in the 2gb one's slot, and the same result. I put everything back to their original state, and now I still only have 7.8 usable
I have reset the BIOS to defaults, used memtest, and everything is fine, set my max memory to 18 gb, then unchecked, no results. I'm at my wit's end, can someone help me?
Model
Brand
HP
Series
ENVY
Model
h8-1534 (H2N64AAR#ABA)
Processor
AMD FX-6200 3.8GHz
Processor Main Features
64 bit 6-Core Processor
Cache Per Processor
6 MB L2 Cache
Memory
10GB DDR3 1600
Storage
2x3tb Toshiba internal hdd
Optical Drive
SuperMulti DVD Burner drive
Graphics
AMD Radeon R9 380x 4gb
Ethernet
Gigabit Ethernet
Power Supply
Corsair C600 psu
Operating System
Windows 8 64-Bit
Motherboard
Chipset
AMD 970
CPU
CPU Type
AMD FX-Series
CPU Speed
FX-6200 (3.80 GHz)
L2 Cache Per CPU
6 MB
L3 Cache Per CPU
8 MB
CPU Main Features
Graphics
GPU/VGA Type
AMD Radeon HD 7570 2GB
Memory
Memory Capacity
10 GB DDR3
Memory Speed
DDR3 1600
Form Factor
DIMM 240-pin
Memory Slot (Total)
4
Maximum Memory Supported
32 GB
Hard Drive
HDD
1.5 TB
HDD Interface
SATA
HDD RPM
7200rpm
Optical Drive
Optical Drive Type
DVD Super Multi
Front Panel Ports
Front USB
2 x USB 3.0
Front Audio Ports
Card Reader
15-in-1 multimedia card reader
Back Panel Ports
PS/2
Video Ports
1 DVI, 1 HDMI, 1 Display Port
Rear USB
4 x USB 2.0
RJ45
1 port
Rear Audio Ports
6 ports
S/P DIF
1 port
Expansion
PCI Slots (Available/Total)
1 x PCI Express x16 (Gen 2.0)
3 x PCI Express x1 (Gen 2.0)
1 x PCI Express mini card (for half-length add-in cards) with USB connector
Well, I reseated them all in different slots. Put the 2x4 stick into the 1 and 3 slots, and the 8gb one into the fourth slot. I guess I fixed it. Gonna try to put the 2gb stick into the 2 slot, and see if I can get all of my ram again. If not, screw it, I guess I fixed it.
