Same / Higher specs but with lower fps?
Anton Paul
19
Hey guys, I have this problem with my newly built pc and it's so frustrating..
Specs:
i7 7700 @ 3.6ghz
Palit nvidia GTX 1060 6gb dual
Teamgroup Elite 4gb 2133hz x 2 (8gb)
Msi b250m mortar
500w Psu
1tb WD Caviar blue Hdd
Moving on, I have seen many benchmarks of GTA V on youtube with lower specs than mine (i.e. i7 6700, i5 6500, i5 6600k, gtx 1060 3gb) with their framerates reaching up to 80-100 on ultra. While if I did the same settings as theirs was, I get 35-60 fps only and averaging on about 50fps. I have installed the latest drivers for my GPU but still, no luck. What am I missing? My Nvidia control panel settings are on default. Any ideas guys? :c
Aerocool Rave 500w. Sorry haha I know the psu doesn't make a difference when it comes to Fps so I didn't write the specific name haha @ThomasKK, I'm running games at 1080p but I still get that fps when I try to run GTA V on ultra. :c
Yes, I have installed all drivers for my mobo and chipset :c
The PSU can indeed make a big difference if it's not up to the task of powering everything all at once; it can be over the wattage requirement of your computer but still be unable to keep up.
Upon further research, apparently that particular PSU has a bit of a bad reputation. Try an Antec or Thermaltake, and make sure you get at least 80+ Bronze efficiency.
It's not just the 80+ rating in this case, although usually it does correspond to higher quality (although it's not a quality indicator in and of itself). While researching your PSU, I found several articles and forum posts saying that particular PSU is poor quality.
Try Antec or Thermaltake; I prefer Antec, as I've had zero issues with their PSUs thus far (and I'm on my second build personally, fourth overall with their PSUs).
http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html?_ga=2.5896179.1579615112.1495713344-1535170364.1469799469
Check out that list. You'll want to avoid anything less than Tier 3.
