Same memory module in dual channel
Oct 30, 2018
43
Iam going to build my pc, can I install the
1st seniaro 2 4gb ddr4 memory module of same model number or
2nd seniaro should I use 2 × 4gb ddr4 kit, what is the difference between the two senario, should I get any problems in first seniaro
rodolphe.viard
292
Hi ,
Using the same model, same reference it will work at a 99% chance rate.
In fact sometimes, different kits even same model/reference can lead to instability.
Manufacturers sell kit because they are tested and certified to be copatible together.
Rodolphe.
