Same mouse design for ALL these mouses?
JFST
114
Hi all,
I have an Ozone Smog and now the scroll wheel is acting weird (i go down, it goes up xD ).
I like it and i have been searching for a similar mouse and i have found the same design with some minor changes:
-ACE OF SWEDEN EDGE 3200 (can't find an English review)
-Aliencraft G11
-Sentey Revolution Pro
-Patriot Viper V560 (the only one available on my country -and not sure if the only one available for all countries-).
And i have seen more that can't find now (pretty sure).
(I am happy to have found "so many" -just 1 for me 😛 - as i thought it was going to be imposible to find another with the same design)
So:___
1- Who does that design? (to track them and be able to find another brand with the same design if i need it)
2-It has a Sensor Avago 9800, i have read it had (maybe has) problems, is it true? (please explain if you can -or post a link if you think it is better- 😉 ).
3- If the sensor is bad, could you help me find a similar design with a better sensor? or just a better sensor? (just to start looking in case the mouse wheel breaks).
I have been using that Ozone Smog with apparently (can't find better info) an Avago 9500 (not sure if too much difference) and i have not noticed any problem so i think maybe you have to get used to any mouse out there.
I think this is not an easy to answer thread, but i can be fun 😛 .
Thanks in advance 😉 .
Yep, that's another one i could not remember. Nice find :) .
I wonder who bought them (Ace of Sweden) and if the original design is from them or from someone else and Ace of Sweden was just one of these companies who "rent" that design.
About Avago 9800 sensors, it is known as ADNS if it helps you to identify it better.
Thought you were going to tell me to avoid that Avago sensor at all cost so maybe, as i said, there is no better sensors, you just need to get used to anything out there 😛 .
