same problems help please
filipGk
5
guys i have and i the same problems can help me anyone please?! i have 64 bit win7 same p55 asus but the evo model 4 gb geil s
himnextdoor
704
85
I suppose you can consider yourself fortunate that there is more than an even chance of this being a software program.
First, though, how long have you had the machine and when did the problem start?
In order to check the hardware, go to BIOS and 'disable' multi-threading and reduce the number of CPU cores that are being used.
Now restart the machine and see if the problem persists.
filipGk
5
since 2010 the problem it is allmost since then. i have hear that the all series p55 from asus have issues with the sata input's is that posible to be the problem? himnextdoor.
himnextdoor
704
85
Did you try what I suggested? What was the outcome?
I can't imagine that the drive is faulty but if it is, we will find out. :)
filipGk
5
can you explaine what you wont me to do because im little rookie. and thanks for your time once again.
(to giive you more details i take the priveous bsod and the 0x0000019 and 18 i think and with the graphic card i have some issues some times with the drivers crash the game and tell me that the driver stop etc. always i have the last drivers)
