Samsung 840 Pro question
pindleton
27
I want to purchase the Samsung 840 Pro. I'm American, but I live in South Korea. I have ordered most of my components in the US to be shipped here. Most components are over priced in Korea--even with shipping and import taxes its cheaper to get many parts from the US instead of South Korea. However, the Samsung SSD is one of those things that makes sense to buy here. But I noticed that the model number for the US one is: MZ-7PD128BW, while the Korean one is MZ-7PD128B/KR.
Does the /KR signify anything other than location of manufacturing? Would there be any differences or compatibility problems with my US purchased components?
I have spoken to Samsung Tech Support by calling 1-800-SAMSUNG and it was very easy. They prolly have similar access where you are. If not, I would contact them by e-mail and ask directly.
Yogi
Oh, and for the compatibility question--here is the build:
1) CPU: (http://www.amazon.com/Intel-i5-4670K-Quad-Core-Desktop-Processor/dp/B00CO8TBOW/) or (http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899) - $234.99
Intel Core i5-4670K Quad-Core Desktop Processor 3.4 GHZ 6 MB Cache - BX80646I54670K
2) CPU Cooling: (http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/) or (http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099) - $34.99
Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
3) RAM: ( http://www.newegg.com/Product/Product.aspx?Item=N82E16820231611 ) - $109.99
G.SKILL Sniper Gaming Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GSR
4) Video card: (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127761) - $199.99
MSI R9 270X GAMING 2G Radeon R9 270X 2GB 256-bit GDDR5 PCI Express 3.0 HDCP Ready CrossFireX Support Video Card
5) Motherboard: ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813157369 ) - $117.99
ASRock Z87 Extreme4 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
6) HDD: (http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00YU4026) - $64.99
Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
7) SSD: (http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00ZD1548)
SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
8) Disk drive: (http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204) - $16.99
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
9) Power supply: (http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200) - $59.99
Rosewill Green Series RG630-S12 630W Continuous @40°C,80 PLUS BRONZE Certified, Single 12V Rail, Active PFC "Compatible with Core i7,i5" Power Supply
10) OS: (http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/) - $89
Windows 7 64 bit
Yogi
