Samsung 850 Pro SSD Issue Initializing
scottpole
4
I bought the SSD a few years ago and used it on my Xbox One up until now with absolutely no issues. Today I decided to start using it on my PC, so I plugged it in and tried to set it up. The issue I'm having is when I try to initialize it with disk manager, I get a "request failed due to fatal device hardware error" message.
I've been scouring the web trying to find similar issues but everything I've seen and tried has amounted to nothing. The drive worked completely fine on my Xbox with zero issues. I figured I would need to format it for PC usage, but I havent been able to get that far. Thanks for the help!
Edit: Also, in disk manager, it shows as unknown, not initialized and there is no storage shown as well.
Edit 2: I also forgot to note that the drive DOES show in BIOS as well.
I was able to initialize the SSD using AOMEI Partition Assistant and then was able to format it and make a volume using disk manager. I'm not sure what exactly I did other than powering down, re-seating the SSD in the external case and reconnecting everything, then powering up. Anyway, thanks for your help!
Hi thanks for your reply! I've tried to run both of the tests on SeaTools as you suggested, sadly both failed. I checked out the other link you posted. I've not been able to assign a letter to the drive yet so that I can format it.
I rebooted my PC and now the drive is actually showing space inside disk manager and when I try to initialize it, it says it is write protected, instead of giving me the fatal error. Also, I'm using USB 3.0 as I don't have an extra SATA cable at the moment. I have an external case for the SSD.
