Samsung 860 evo problems installing
Jul 19, 2018
4
I recently tried to install a Samsung 860 evo 250gb but on migrating Windows over using their cloning software it wood not boot. I tried this multiple times but had the same issue. I then thought it was probably something to do with it migrating so did a fresh install but still had the same outcome. I even swapped the drive incase it was faulty. Motherboard is an Asus rog maximus VI and current ssd is a Sandisk plus 60gb which is still working fine. Does any one have any ideas on solving the issue? Thanks
Jul 19, 2018
4
Yes went to the bios and made sure it was at the top. Also tried it with no other drives installed.
garyoa1
13
I got an 860 500gb. Tried to install as a slave. Win10 pro doesn't see it. Doesn't show in disk management. Tried another sata cable... nothing. Pulled another drive out of the machine (desktop, 4 drives) and tried it there. Nothing. Anyway, it was a 4 month old drive sitting on the shelf. Got it at amazon. So I assumed amazon would be out of the picture so contacted samsung. They said contact amazon. (what?) Of course amazon said contact samsung. So essentially I have a new dead drive with no warranty. Looking thru amazons comments it would seem there are a LOT of folks with essentially the same problem.
Similar threads
