Question Samsung 960 evo plus not showing in disc managament
Sep 29, 2019
4
Hello
I've bought a 960 evo plus some says ago, my OS is on a Samsung 850 evo. My problem is that the new 960 is not visible in disc management and I've planned to install my main programs and OS on that disc.
Any HDD and other SSD dics are visible in disc managment if I plugg them in, I'n not using more than one SSD at the moment.
The 960 is visible in bios and below storage units and so on so it seems to be correctly installed.
I've tired to unninstal windows nvme drivers, same with Samsungs nvme driver and rebooted the system without luck.
Tried to change the sata port if I've missunderstood the manual but the manual is saying that the one m2 port i have will not interfer with any of the four sata ports i have.
What can i do? im out of ideas.
Best regards
Sorry, was a bit fast to post..
MB; Asrock 370x mitx gaming fatility
CPU, ryzen 3700x
storage; 960 evo plus and 850 evo both samsung
Ram, cant remember 16 gb something
PSU; 850 seasonic platinum
GPU RTX 2080
Cooling; custom cooling on cpu/gpu
solved it, at the latest bios update i got some new feture that i didnt have at earlier versions. could make a Clean wipe directly from bios and after the wipe windows could recognize it. i Think that after the first time i connected the drive i choose some settings for the nvme that wasn't compatible with my OS.
