Samsung 960 Pro SSD - not getting the max speed
euorinsm
6
Is there anyway to tell if I am getting the max speed out of my SSD? I have a feeling it's not. I double checked, I installed the nvme drivers, have the latest firmware. I have drive indexing turned off. I ran the Magician benchmark utility and for the result this is what I got:
Sequential (MB/s) Read: 2,791 Write: 1,934
Random(IOPS) Read:338,080 Write: 338,892
attachment.php
Can anyone check to see if its normal?
That MB supports all current NVME drives. Anyway, besides trying a PCIe M.2 adapter you may want to uninstall then reinstall the NVME driver from Samsung and see if that helps.
The Samsung Magician performance test has been extremely inconsistent and unreliable. Suggest you test with Crystal DisKMark. For less inflated results (and maybe more accurate) try AS SSD Benchmark.
That seems pretty close to Samsung's speed claims. The difference is negligible:
960 PRO
Form Factor
M.2
Capacity
512 GB, 1024 GB, 2048 GB
Sequential Read Speed
Max 3,500 MB/sec
Sequential Write Speed
Max 2,100 MB/sec
I know i'm probably asking for too much, but I still think that score could be improved a little bit. I seen some people who've had a higher score than I do, and my hardware is really good. Can there be something else I'm missing?
Size of the drive vrs what's actually used, if the drive is more than 1/2 full, expect a little slow down. Motherboard capability and performance. Some mobo's simply don't quite live upto full performance claims, they might be 98% capable, which is close enough. But that 2% will show up in your benchmark as slightly slower speeds. NVMe and mobo drivers the same, might not be a full 100% optimized, might be only 98% optimized, so benchmark is affected.
Your speeds are close enough to Samsung ability that it honestly makes 0 difference to anything but a benchmark. On something like a 1hr run stress bench, you'd see a few seconds at most difference
The only thing that I can suggest is if using a built in M.2 slot on your MB, instead try a PCIe M.2 adapter card.
I am using one for my 960 EVO 250GB boot drive and getting Samsung stated speeds (btw, the 960 EVO costs much less, ~$130, than the 960 Pro and offers just about the same speeds):
Yeah that's really strange, you have the EVO version and your scores are a little better than mine even though I have the faster version. I don't have an M.2 adapter to test it , but my I know my motherboard is capable of those speeds. And here is my motherboard btw:
http://www.gigabyte.com/Motherboard/GA-X99-Ultra-Gaming-rev-10#ov
On their M.2 support list you'll see it has the 950 Pro on there , but i guess they didn't update it for the 960.
