Samsung B- Die Guide
NKR 8055
Commendable
Jul 24, 2017
33
Good Day all.
As the title suggests, im looking for some clarification regarding samsung B die. there are existing links on the subject such as https://www.reddit.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
but its not quite an ideal guide for a first time builder.
is there a way to request for TOMS to make such an an article regarding the subject of samsung b die RAM ? is there an existing article with clear explanations and product list?
Thanks in advance
Aside from the list you already have, there is this:
https://www.amd.com/system/files/2017-06/am4-motherboard-memory-support-list-en_0.pdf
this:
http://www.overclock.net/forum/18051-memory/1627555-ryzen-memory-ic-collection-thread.html
and whatever specific modules and sets are listed on the manufacturer specific QVL list for your motherboard model that are listed on the CPU/memory compatibility tab on your motherboard product page.
That's pretty much all I am aware of as far as what is definitively compatible. The Flare-X sticks are a good bet since the XMP profiles on them are specific to Ryzen rather than to Intel configurations unlike non-Flare X modules, which are specifically tailored for Intel configurations.
this:
NKR 8055
Commendable
Jul 24, 2017
33
Thank you again kind sir
the reason for starting this thread was the suggestion you made on my previous thread regarding ram compatibility. after you suggested going with corsair dominator i didin't bother looking at anything else. i just wanted to hopefully help out anyone else looking for the same info.
