Samsung b1930 help
xaeen
17
hi,
i bought b1930n yesterday but it is not giving that much good video result. . . the same video file when played on my 17 incher crt . . it performs well. . . what can be the problem? please help!!!
Adjust display settings in Windows to the new monitor's native resolution and refresh rate.
As the new monitor is (doubtless) larger than the old one you are demanding more of your video card -- maybe an upgrade there too ?
THIS MONITOR HAS HIGH RESOLUTION SO YOUR LOW RESLOLUTION VIDEO WILL PLAY SMALLER IN SIZE AND LESS EFFECT WHEN YHE SAME VIDEO IS PLAYED IN 17 INCH CRT IT HAS LOW RESLOUTION SO THE VIDEO IS ALSO LESS RESOLUTION IT WILL PLAY CLEAR
