Samsung Evo 250gb or Samsung Pro 128gb
f___
11
I'm only putting the OS and probably 1-2 games onto my ssd. In terms of speed (launching programs fast) which is better?
Is the Samsung EVO 250gb better or samsung 128gb PRO?
Help me
250gb is better, in my opinion.
Larger ssd drives are a bit faster because they have more nand chips that can be accessed in parallel.
The extra nand will also result in better updates because it is easier to find an empty nand block.
The main advantage of a PRO is endurance. Likely a useful life of 15 years vs. 10. It is a moot point, both will be obsolete before they wear out.
128gb Pro should be slightly faster and has better warranty (which you shouldn't need). They can both utilize RAPID and it would make them pretty similar until you run out of free space on the 128gb.
