Samsung Evo SSD Issues - Need help!
Shaun98
462
Hi, its been a few months now since ive had my SSD however I am having some annoying issues with it that ill list below.
1. Samsung magician says AHCI mode deactivated (IDE or Raid) How do I fix this?
2 Samsung magician says Sata interface N/A (Unable to detect sata interface details)
and lastly
3.I cant gain permissions to my SSD I get the error - C:\ Failed to enumerate objects in the container. Access is denied
if I click continue I get unable to save permission changes on local disk (C:) Access is denied
Please if anyone has any knowledge on SSD's can you post any ideas you may have below.
Thanks! Shaun
Thanks for the help everyone!
SOLUTION -
CONNECTED MY SSD INTO THE ASMEDIA 6GB PORT AND CHANGED SETTINGS TO AHCI AND IT NOW WORKS
This setting is in your MOBO BIOS. As stated, selections are AHCI, IDE, or RAID. Unless you're setting up a RAID array, set it to "AHCI". BE SURE TO SAVE YOUR SETTING before exiting BIOS.
Try the above and see if you are still getting the other 2 problems.
Yogi
SPECS -
2TB Sata III Hard Drive
AMD FX-6300 CPU
Vibox Predator Green Gaming Case
16GB Corsair Vengeance 1600MHz Gaming RAM
Microsoft Windows 8.1 64bit OEM
500W Vibox (FSP) PSU
Top LED Green Kit
AMD R9-270 GPU
AIDOS RAIJINTEK CPU COOLER
24x DVD-RW Optical Drive
Mobo is 760gm-p43 FX by msi
Why is that?
Its a secondary controller. Secondary controllers never reach full SATA 6gb/s capability.
Ah ok Thanks for your help anyway
