Samsung Full HD Monitor - S22B370H HDMI Problem
sriramjaya
5
Hi,
Recently purchased Samsung Full HD Monitor - S22B370H
I had tried connecting HDMI ( PC) to HDMI ( Monitor) using HDMI Cable. I am using Nvidia Graphic Card - GT 240 (http://www.nvidia.in/object/product_geforce_gt_240_in.html) which has option for connecting the HDMI Slot.
However I was not able to receive the HDMI Signal in my monitor instead only the VGA option is working right now.
I have connected the cables correctly.
Is there anything that needs to be changed.
Kindly help me out in sorting this issue.
Regards,
Sriram
India.
Yea the problem might be simple, when you're using the VGA cable. Try to get access to the main menu of the Samsung monitor, and select monitor input to be HDMI or DVI...whatever you wish. Then you'll find the monitor went black just pull out the VGA cable, insert the HDMI cable and restart PC.
sriramjaya
5
Hi,
My Monitor has got 2 signals i.e VGA and HDMI and graphics card is VGA, HDMI and DVI.
I had already tried connecting HDMI TO HDMI but its of no use monitor is going blank.
I had ordered for DVI to HDMI adaptor for connecting graphics card DVI slot to HDMI slot in Monitor.
Hope it works
Note : Samsung technical person has personally come and checked and informed that there are no issues in Monitor.
Regards,
Sriram
India.
alps2cool
Hi,
In the BIOS u have to change/enable the D-SUB/HDMI option under advanced settings. Usually D-SUB/DVI option will be enabled by default. Try this.
Regards,
Alphin
India
ar_itra
There is a button, a rectangle with arrow in sides, in the front panel. That changes the input. press it.
