My external hardrive failed 1 and a half years after use.Its not under warranty anymore.
Basically it boots up,and is detected but cannot be accessed.The pop-up window says the drive cannot be access until formatted.
I removed the drive from the case,and connected it to the computer with no change.
I downloaded Seagate tools for window and the drive failed every test.
DFT for windows shows the fail for Smart check,but a pass for "read error check".The status of the test is failure.
Is there any way to recover the data on my own?Or if I format the harddrive will it be recoverable or is that just a system glitch?
I cannot run Seagate tools for dos since I don't have a cd-rom.
Any help with salvaging the contents of the hard-drive or the harddrive itself will be helpful.Thanks.
