samsung magician rapid mode issue...
Shuten
74
im having an issue with the samsung magician rapid mode, i had the rapid mode enabled before then it starts telling me whenever i boot up my pc that rapid mode has failed to start. when i check it out it shows the requirements it needs, i look at the cpu it says it needs 1.00 Gh minimum, recommended 2.00 Gh. the processor i have is an i5 4690k 3.5 Gh processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372
but on the samsung magician it says i only have .80 Gh which shouldnt be right. how do i fix this?
Note: btw my samsung magician version is 6.3.9600
ok i checked around and it shows me that my cpu is only running at around .80 Gh. im not sure why it does that and i dunno if its supposed to do that. how do i get it to use more if that will fix my issue with samsung magician?
Hi, I am using Magician 4.6. You have mentioned your magician version is 6.1.9600, Is this the OS version number. I am little confused on this version no. PC mode, OS, drivers and driver version this issue is occuring. Is this PC having Intel Turbo Boost? or some other SW like this?
