[SOLVED] Samsung Monitor Ghosting
hadrian.diaz
12
So I've had this problem for a year, I've sent it in twice changed cables used a bunch of different settings and it still has that ghosting problem. Any ideas of what or how to fix this?
I would check the manual on it.. and if you have an amd vid card make sure you have the correct input being used for the monitor. like the one I have has 3 inputs but only one is freesync. and try some of the settings on and off.
Its a LC24FG70FQNXZA, a curved free sync monitor.
