Samsung monitor has blank screen despite working well
Ricky58
5
My samsung monitor is S22D300. I connected to the laptop using an HDMI adapter because the laptop doesn't have a VGA port. After trying i got it working but now the same thing is happening again. The screen is blank even thought it's detected by the laptop. It must be a driver issue. What could i do?
I use an adapter that converts it to HDMI. It worked fine for a bit but after that it became blank again. It must be for sure something with the driver. What else could i try?
No. But i saw it working fine. While installing the driver i saw a screen saying to choose between S22D300( VGA) and S22D300(HDMI),Which one should i choose since that i'm using an adapter? I'm afraid that's the issue.
Ok...Maybe if i would try another VGA cable with that adapter could change anything?
Yes, i did it.
