Review Samsung Odyssey OLED G8 Gaming Monitor Review: High-Performance Gaming With Smart TV
Actually you made a mistake, it uses an HDMI MICRO Input so you need an HDMI micro cable or adapter. Not mini. You should correct that.
Pretty low refresh rate for such an expensive "gaming" monitor. Should be at least 240 Hz and even then it'd be expensive.
Wow. This review is so way off. I've owned this monitor for several months and it has problems that Samsung has or is still working on to correct.
1) Putting the monitor into "movie mode", actually called "entertain" mode disables its "game mode" which in turn disables HDR, "adaptive sync", and lowers the max FPS to a maximum of 120.
2) This monitor also has some compatibility issues with GPU's ports. Both HDMI and DP. The problem is when you power down your PC and the monitor goes into standby mode, it has to be powered up manually with its remote each time you power up your PC.
This monitor shines on being a standalone entertainment streaming device. But it has some issues trying to act like a simple PC monitor. I'd get the Alienware versions.
Maybe the reviewer has an updated firmware version I don't...yet. But I check daily.
By the way, when it is configured correctly this OLED monitor is amazing in gaming. And for the record, none of the above holds a candle to its color depth and image quality in gaming. You'll see HDR as it is meant to be. You can verify that by searching for and reading other reviews on this monitor. This panel, Alienware, Samsung, MSI is in a league of its own.
Hm... nothing about the sub-pixel layout? Has it got the same color fringing issues with text as the Alienware displays?
The fact this has no audio out is pretty rubbish. I've got a 2013 TV with a headphone/AUX out that I use with a couple of good flat studio monitors & a sub via miniDSP, so a TV without any audio out capabilities is a bit rubbish in 2023, but I guess the picture's good!
I hate these combo platter all in one devices for $1k+. One of the biggest mistakes Ive recently made is get 2 x G70B IPS with a variation of this horrific OS underlying. The monitors are great, designer wife uses them as flanking monitors. But... If you want updates consent to screen scrapes. Any other samsung controller around? They seem to all work on these, especially when you dont want it. Convoluted menus are terrible using the on display controls.
You may ask why not use the controller? Well with two monitors that respond to any samsung remote command... better hope the actual panels are identical when calibrating or you're using on display controls... no turning remotes off as far as I can tell. It seems to me that these one product for everything devices are better suited for entry-mid level monitors. People that may not be able to afford multiple devices or want to spend the money on a highend monitor seem like the target demo. It just feels like a TV with some monitor functionality built in.
Sorry, rant over - I honestly was working on her setup and wanted to destory both of the G70B's moments before I saw this.
Unless you are able to personally inspect and purchase ocean front property in Arizona, never, ever, ever, buy anything from Samsung that is dependent upon whatever new and totally unique slapped together and soon neglected software that gets haphazardly shoved up their display products. They may make good hardware, but they do not put any effort into the software side. Except for the parts that report back your tv usage. Not sure I want to know what they report back when it comes to something specifically designed to be hooked up to your computer.
In my opinion, 175 Hz is enough for a gaming monitor. Keep in mind that to get 3D rendering that can handle 240 Hz requires a very expensive video card, and it is not a given that you will get the highest quality with some games.
So 240 Hz is wasted if you want to aim for rendering quality unless you practice esports where response/latency is important, and not visual quality.
People who buy this monitor I think want to have better visual quality.
The competition is selling the same 34 OLED at 240hz cheaper ...... hence this one is "too slow" for the asking price, it should be cheaper or at least sport 240hz refresh
Reactions: MoxNix
