Samsung replacement wireless lan
Mike Hall SP PA
Does anyone know of a compatible wireless lan card for Samsing np470r5e laptop.
I do not want atheros ar9485wb-eg as this is whats in it and has connectivity issues. This is a known issue with this card. I would want to replace it with one that could also connect at the 5ghz range. All ideas or help is appreciated
A doubt another brand wireless card will work. If you don't want to get another atheros ar9485wb card then all you need to do is to get a usb wireless device. The work fine and most times even better than the wireless card and capability of the laptop it self. Get the TP-LINK TL-WDN3200 N600 Dual Band Wireless USB Adapter
http://www.amazon.com/gp/product/B007ZWL1ZE/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B007ZWL1ZE&linkCode=as2&tag=newtomshardware-20
N600 Dual Band connections for lag-free HD video streaming and gaming
Maximum speed up to 300Mbps at 2.4GHz or 5GHz
Easy setup at a push of the WPS button
Support Windows XP/Vista/7/8
