I just finished upgrading and changing most of the components in my PC and everything is working great except one thing. I have the Samsung 850 Pro 128Gb SSD and from time to time it freezes for around 3-4 seconds, in that time it makes a weird sound that goes from low to high pitch, then it "pops" and continues to work as it should. Most of the time it happens on startup before POST or when you want to make a shut down or reset and sometimes when you are opening a new folder or things like that.
I'm assuming that it's the SSD because this started happening before i changed the cpu,mobo,ram,psu on my previous PC, right after buying this drive but i thought the problem will be solved now after the upgrade and also a fresh windows install (went from Win7 to Win10 Pro 64bit). When the freeze happens it pushes the CPU to 100%.
Also i have this problem which i didn't have before with the previous components that in Samsung magician AHCI is not recognizable (AHCI mode is required for best SSD performance) (Unable to detect SATA interface details) but i have AHCI enabled in BIOS where i don't even have an option to switch to IDE.
Build:
Samsung hd103sj 1T HDD
CPU - i7 6700k Skylake 4.0 Ghz
MoBo - Asus z170-a
GPU - ATI Radeon 5870 HD
RAM - G skill ripjaws 2400MHz - 16Gb
PSU - Corsair mi650W
Build:
MoBo - Asus z170-a
