Samsung SyncMaster SA300 Resolution Problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Guys, I have a problem. I buyed this monitor about four months and in the shop they seed that it is compatable on a resolution of 1920X1080, but when I started the computer it did not fit on the monitor(resolution 1920X1080). I lowered to 1680X1020, but I want it to be on a resolution 1920X1020.
Thanks in advance.
My video card is a AMD Radeon HD 7750 2GB and the monitor is connected over a HDMI cabel.
Then you should be able to go into the Catalyst Control Center, and one of the menus has an option for adding HDTV modes. You can add 1080p60, which means 1920x1080. You'll probably need to adjust overscan/underscan to really get native resolution.
