Considering past comments and the timing of Samsung's upcoming presentation at ISSCC, though, GDDR7-equipped GPUs will likely find their way to us before the end of the year.
Seems unlikely though from a broader perspective. Some of the GPUs will land up with GDDR6X chips as well.
Also, I doubt these faster speeds will be ready and produced in enough mass quantities for the next-gen gaming and AI GPU lineups, but at the most, we can expect R7 32 Gbps speeds in some of the upcoming generation of flagship gaming GPUs, i.e. RTX 50-series "Blackwell" graphics cards, as well as AMD's RDNA4-based RX 8000 series.
Seems too optimistic for the industry to expect 37 Gbps pin speeds on consumer level gaming cards from both Nvidia and AMD anytime soon though IMO.
Because not all next-generation GPUs will max out 37 Gbps, some may run at lower memory speeds, and they have suitable options in the SK Hynix product stack as well.
But assuming it indeed pans out, then following would be the "expected" bandwidth the
37 Gbps pin speeds would offer across multiple bus configurations (gaming GPUs):
- 512-bit - 2368 GB/s (2.3 TB/s)
- 384-bit - 1776 GB/s (1.7 TB/s)
- 320-bit - 1480 GB/s (1.5 TB/s)
- 256-bit - 1184 GB/s (1.2 TB/s)
- 192-bit - 888 GB/s
- 128-bit - 592 GB/s
