Samsung Vesa Mount
FAHADPC
29
I want this vesa mount for my s24d590pl
https://www.amazon.com/Adapter-Monitors-U28D590D-S27D590P-S24D590PL/dp/B01BFWRI4M/ref=sr_1_1?ie=UTF8&qid=1488308727&sr=8-1&keywords=vesa%2Bmount%2Bfor%2Bsamsung&th=1
but people are saying i need a spacer because the stand tilts the monitor back a bit
can someone tell me what a spacer is and how its installed??
and will this work on my monitor??
https://www.amazon.com/Samsung-23-6-Inch-LED-lit-Monitor-S24D590PL/dp/B00IEZGYI0/ref=sr_1_1?ie=UTF8&qid=1488309398&sr=8-1&keywords=s24d590pl
If you don't have an articulating arm(for the vertical plane, then you're going to need some washers/spacers that go between the screws to the top of the mount which will go into the wall mounted arm.
Step 2
^ out of the 4 screws that go from the wall mount to the adapter, the top two screws will require an additional washer to add some depth and thus add some distance for the monitor to be tilted towards you instead of away from you.
Step 2
